I am using BCM20737S included in Macnica koshian.
Koshian - Mpression
I use PUART for debug trace by ble_tracex and it works fine.
Now I changed the port for debug trace to HCI, but it does not work correctly.
PC terminal does not show any messages.
Followings are my code.
const BLE_PROFILE_PUART_CFG eval_puart_cfg =
    /*.baudrate    =*/ 115200,
    /*.txpin    =*/ PUARTDISABLE,
    /*.rxpin    =*/ PUARTDISABLE
APPLICATION_INIT()
    bleapp_trace_enable = BLE_TRACE_UART_HCI;
Any hardware configuration need or my firmware is wrong?
Can anyone answer?
Thank you in advance.
Koshian is not designed for software development.
And I recommend to use BCM92073X_LE_KIT for it including viewing debug trace.
I can see debug trace from HCI UART with any sample application on LE_KIT easily.
So please try running existing sample like hello_sensor on LE_KIT first.
If you see the debug trace from HCI UART, then the debug trace will work on Koshian I think.
MichaelF_56
Adding 79rpm​ and dmiya of Macnica.
MiTo_1583836
Let me do some research in Japan and I get back to you.
Thank you all for reply.
I understood koshian is not suitable for software development.
I should use PUART for debug trace because I don't have BCM92073X_LE_KIT.
