Dear Team
I would like to ask you to check a possibility regarding tuning the advertisement channel, For example, they will be corresponded with an each channel as follow, also they will be used for the BLE scanning activity for each channel.
1st BLE chipset tune for 37 advertisement channel.
2nd BLE chipset tune for 38 advertisement channel.
3rd BLE chipset tune for 39 advertisement channel.
Would you please help the possibility?
Thank you
Daniel
MichaelF_56
The BLE spec allows for 40 2MHz channels, 37 of which are used for data and 3 for advertising (ch 37-39).   Unfortunately, there is not a straight forward means by which to force advertising on just one of the three available channels.
MichaelF_56
Thanks for the reply, according to our new product, it will have multi-function for BLE passive scanner feature, so I just consider to use three BLE chip that will be corresponded with each BLE channel in order to incresase more BLE scaned data rate. so would you please consider again for the passive scanning work with one BLE channel?
