Nov 09, 2014
11:50 PM
Nov 09, 2014
11:50 PM
I used the below to set up PUART flow control,
puart_selectUartPads(((bleprofile_puart_p_cxfg->rxpin / 16) << 5) | (bleprofile_puart_p_cfg->rxpin % 16),
3, 1);
puart_init();
puart_flowOn();
and the WP pin of my test platform is set to P32.
There are only 16 bytes of data received and some data lost when transferring over 16 bytes of data.
The RTS pin of the PUART seems not work.
Thanks!
Jack Huang
Labels
Peripherhal UART
07:08 AM
Nov 10, 2014
07:08 AM
There is a discussion here that explains why RTS doesn't work...
