- Email to a Friend
How can I register callback for ADV events, for example when the timer for HIGH_UNDIRECTED_DISCOVERABLE expires ?
I managed to do similar thing for SCAN events using:
blecen_usertimerCb = hello_client_timer_callback;
but this does not work for ADV events.
- Email to a Friend
on_timer_events()
if (running_high_duty_adverts && (time_since_started_high_duty_adverts == 31) && need_to_keep_high_duty_adverts)
start_high_duty_adverts();
- Email to a Friend
you can register event to be notified when advertisements stop
bleprofile_regAppEvtHandler(BLECM_APP_EVT_ADV_TIMEOUT, hello_sensor_advertisement_stopped);
If you need to know when advertisement changes from high duty to low duty, you will need to monitor time. For example if you configured high duty advertisement durations for 30 seconds
/*.high_undirect_adv_duration =*/ 30, // seconds
and you have 1 second timer running
bleprofile_regTimerCb(hello_sensor_fine_timeout, hello_sensor_timeout);
bleprofile_StartTimer();
you can bet that after 30 times you enter hello_sensor_timeout the advertisements will go from high duty to low duty.
- Email to a Friend
I need to intercept the transition HIGH->LOW and LOW->OFF (before it happens)
For SCAN it can be done this way:
extern BLEAPP_TIMER_CB blecen_usertimerCb;
void app_create(void)
blecen_usertimerCb = app_timer_callback ;
void app_timer_callback(UINT32 arg)
switch(arg)
case BLEAPP_APP_TIMER_SCAN:
if (blecen_GetScan() == HIGH_SCAN)
//custom code here
else if (blecen_GetScan() == LOW_SCAN)
//custom code here
break;
Please note that the above also works for CONN:
just add:
case BLEAPP_APP_TIMER_CONN:
but it does not work for:
case BLEAPP_APP_TIMER_ADV:
So how can I do same thing for ADV ?
Why is BLEAPP_APP_TIMER_ADV special ? how to handle it ?
- Email to a Friend
There is no API for that. If you set high duty advertisements for 30 seconds and you want to be notified before that the best resolution you can get is 30 seconds - 12.5 milliseconds. And this is done only using timers. And as I mentioned you are notified when transition is to OFF.
- Email to a Friend
The reason I want to intercept this event is that I want to control the transition:
Here is working example for SCAN:
//decide whether change to LOW_SCAN or not
if (change_to_low)
blecen_Scan(LOW_SCAN);
Knowing only when this happens using different timer does not help here.
Is it possible at all for ADV ?
- Email to a Friend
on_timer_events()
- Email to a Friend
is there a reason why :
unlike:
BLEAPP_APP_TIMER_CONN and
cannot be handled in user's timer callback ?
- Email to a Friend
Very good question. We will consider your suggestion for the next version of ROM.
