- Email to a Friend
If any services and characteristics are not displayed in LightBlue app, is there the way to regain them?
Debug
- Email to a Friend
When you add LEGATTDB_PERM_WRITE_REQ you need to change CHARACTERISTIC_UUID16 to CHARACTERISTIC_UUID16_WRITABLE
- Email to a Friend
Have you tried to "Forget this Device" on the handset side, then reconnecting? I believe other users had a similar issue and this resolved their problem.
- Email to a Friend
Hi, mwf_mmfae
Yes. However, although the Local Name in LightBlue app is displayed the correct name, I can't regain them.
The name displayed in Peripherals Nearby in LightBlue is incorrect.
Though, I restarts BL Switch of iPhone and trys "Forget this Device", reconnect, a name of other projects is denoted.
Then, I returned the source code by using Git, but I couldn't take them back.
What can I do anything else?
- Email to a Friend
Not sure. We will need to check with the developers this week.
- Email to a Friend
Hi, mwf_mmfae
I got the cause to disappear all services and characteristics.
After I add LEGATTDB_PERM_WRITE_REQ to CHARACTERISTIC_UUID16 of Device Name,
they doesn't become to display.
Although I modify .wic file, there are all of them.
However, just as I add the permission to Device Name, they disappears.
How can I add a permission which is to write with response to change Device Name in development?
Best Regards
- Email to a Friend
Hi, mwf_mmfae
Is there a way to add permission to edit Device Name to CHARACTERISTIC_UUID16 without not losing services and characteristics?
Best Regards
- Email to a Friend
- Email to a Friend
Hi, victorz
Thank you for your response.
Do you say that I have to change the following code:
//<Name>Device Name</Name>
//<Uuid>2A00</Uuid>
CHARACTERISTIC_UUID16 (HDLC_GENERIC_ACCESS_DEVICE_NAME,
HDLC_GENERIC_ACCESS_DEVICE_NAME_VALUE,
UUID_CHARACTERISTIC_DEVICE_NAME,
LEGATTDB_CHAR_PROP_READ,
LEGATTDB_PERM_READABLE | LEGATTDB_PERM_WRITE_REQ,
8),
to like following code:
//<Uuid>2A00</Uuid>
CHARACTERISTIC_UUID16 _WRITABLE(HDLC_GENERIC_ACCESS_DEVICE_NAME,
8),
The former code is generated automatically by Smart Designer the write permission of which is checked in our other projects.
Do I need to change CHARACTERISTIC_UUID16 to CHARACTERISTIC_UUID16_WRITABLE?
Anyway, when I edited like you said, my services and characteristics didn't disappeared.
Thank you very much for your advice.
However, I have not confirmed that my custom board works correctly.
So, if there is the other method to solve this problem, I want you to tell me about it.
Best Regards
- Email to a Friend
Do not forget to change properties as well. Properties is something that your client will discover. He needs to know that you support Write (or Write no Response), for example
//<Uuid>2A00</Uuid>
LEGATTDB_CHAR_PROP_READ | LEGATTDB_CHAR_PROP_WRITE,
8),
