How to mass program EEPROM for BCM20736?
We are using BCM20736 for our product, and have to program EEPROM with our application. How do we do this at production stage?
My specific questions are :
1. I understand Avnet is setup for mass programming. What are the pieces we need to share with Avnet so that they can program EEPROM?
2. How is EEPROM programmed ? Can it be programmed as a separate, standalone IC before it is put on our boards? Or does it need to be connected to BCM20736 for it to be programmed by Avnet ?
MichaelF_56
I will ask someone from Avnet to reach out to you at the local level.
Avnet then has specialist with direct access to our factory team if there are questions.
andrew997jaeyoung
