How to know if the reset reason is watchdog or others
Hi Sir,
   There are "mia_isResetReasonPor" to get wake up reason for  PoR or deep sleep,
   additionally, is there any way to get the reset reason for PoR or WatchDog ?
Check the other link under WICED Smart User's Guide -> Watchdog Timer
It should answer your question.
-Kevin
BoonT_56
The current two reset reasons are mia_isResetReasonPor and mia_isResetReasonTimedWake. You may try to ascertain whether a reset is due to watchdog by observing for it when the watchdog is enabled and disabled.
Increasing/Disabling the watchdog timer
-Kevin
frank is this still an issue?
Our device is using with BLE 20737S and when system is reset due to some exception, I try to
query mia_isResetReasonPor() but the reason code = 1 which is the same as normal power-on reason.
Is that correct or wrong; I originally think there will have different reason from normal power-on reason.
The reason is correct. But it did not say what is the trigger to your exception.
