07:31 PM
Nov 12, 2013
07:31 PM
Hi Team, Can you please inform how to dump FW from EEPROM ? Another, I test the download FW tools by Bluetool & BLE SDK 1.0.1 . The function is the same but power consumption is different. The power consumption by SDK is bigger than download by Bluetool. (Raise around 2mA).
- bcm20732
- built
- concerned
- contents
- correctly
- current
- deployed
- download
- downloaded
- downloads
- dump
- eeprom
- firmware
- frank
- higher
- idesdk
- implemented
- issue
- item
- method
- present
- provide
- recorded
- release
- script
- support
- time
- tool
- tools
- v1.0.1
- verifies
- written
07:42 AM
Nov 24, 2013
07:42 AM
Hi all, thanks^^. It is happy to get the users manual, I will contact our distributor to apply "Loader".
We have a command line solution using a set of tools (with users manual) we provide which allows customers to load firmware within a manufacturing enviironment, but the package (called "Loader") requires an NDA. Do you have a local distributor that you are working with who can work with you to get an NDA in place? Once that is in place/verified, I can send them the files to provide to you. Note that one of them is similar to the Chipload.exe utility that is provided within the tools directory of the SDK.
