Dear All,
Would please help me to figure out how i can change Transmit power to 9db on CYBT-353027-EVAL?
Hi yans
It certainly helpful and let me change the advertise transmit power . i did test a line of site test with having different TX power set (i don't have required information to measure it precisely ).
and the result shows from -16 to +4 you can see gradually change in RF strength (100 sample each time with 1 sec RSSI measurement using FrontLine PBA 600).
but from +4 to +8 strangely the signal weaker this time i tried (1000 sample for each same environment , same setup).
i used wiced_bt_dev_set_adv_tx_power() to change advertise transmit power. and hello_sensor sample code (i purposely didnt change any thing except adding line to change advertise transmit power )
Please Advise.
Per my test, it works well. Attached my test pic.
Also I used the hello_sensor and change the name to "Nihao". First pic refer to 4dBm. Second pic refer to 8 dBm."
