- Email to a Friend
Hi all
I intend to use MCP9808 (i2c temperature sensor).
http://www.farnell.com/datasheets/1522173.pdf
So, I wrote codes like below.
==================in Constants========================
// Read operation to the lower level driver is 0.
#define I2C_SLAVE_OPERATION_READ (0)
// Write operation to the lower level driver is 1.
#define I2C_SLAVE_OPERATION_WRITE (1)
#define MCP9808_SLAVE_ADDRESS (0x18 << 1)
==============in timer_1s()============================
UINT16 data = 0;
temperature_sensor_read_16_bit_register(0x05, &data);
However,
cfa_bsc_Opextended in temperature_sensor_read_16_bit_register always returns CFA_BSC_STATUS_NO_ACK.
I edited a part of temperature_sensor_read_16_bit_register like following:
read_status = cfa_bsc_OpExtended(reg_bytes_to_read, sizeof(reg_bytes_to_read), reg_read_bytes_to_write,
sizeof(reg_read_bytes_to_write), MCP9808_SLAVE_ADDRESS, I2C_SLAVE_OPERATION_READ);
Why do these code work correctly?
Is there anyone who could make temperature_sensor_read_16_bit_register work correctly?
Please tell me what to do.
Sincerely,
Ishikawa.
I2C
- Email to a Friend
Hi, arvinds and j.t.
I'm sorry for my late reply.
I could confirm that i2c function which I implemented works correctly by using my self made board and the same code. However, I couldn't identify the cause of the problem....I apologize.
I'd like to express my deepest appreciation for your help and support, arvinds and j.t.
- Email to a Friend
Hello Ishikawa,
Broadcom provides a sample code set for attaching several different sensors to the BCM20737:
WICED Sense Kit using SDK 2.2:
- WICED Sensor Data Format
- WICED Sense Firmware Source Kit
- WICED Sense Firmware Walk-Thru Video
- WICED Sense Recovery Procedure Video
- Procedure for Running WICED Sense Tag on USB Power
These examples should provide you with connecting sensors to the I2C bus.
JT
- Email to a Friend
Have you taken a look at the i2c_temperature_sensor sample application within the SDK?
Leveraging the well known LM73 Temperature Sensor from National (now TI), this example provides a proven example showing how to read/write data from/to the LM73, along with the handling of ALERT interrupts from the sensor.
Also, keep in mind that alot of customers struggle with the slave addressing when first implementing a new/custon I2C sensor of their own.
For this, the developers have recommended that you try tracing the I2C lines on an oscope or a logic analyzer to see if the right address is on the bus and the slave is acking it.
This thread contains this advice and some other excellent I2C debug information: how can i use to i2c between bmi160 sensor and BCM20732?
- Email to a Friend
Please check your schematic first.
Are all A0-A2 tied to GND?
What is the voltage supplying to MCP9808?
The operating voltage is 2.7 to 5.5V.
- Email to a Friend
dmiya, j.t, mwf_mmfae
Thank you for responding!
I'm so sorry that I didn't check the voltage of VDDIO of I2C of evaluation board....
The voltage of this pin is 1.8V.I assumed that the voltage of this pin is 3.3V.
I sincerely apologize.
Well, I want to resolve this problem.
Can I edit the voltage by changing the resistances named RFB1, RFB2 and C22 in Hardware User Guide (SDK 2.x and TAG3 Board)?
- Email to a Friend
A voltage divider is required.
- Email to a Friend
Hi all
I checked the signal I2C bus by using Oscilloscope.
Why does the cycle of i2c is 10us (SCL is purple)?
Is the frequency of cfa_xx functions 400kHz isn't it? (The cycle of SCL shoud be 2.5us, shouldn't it?)
Furthermore, SDA which is yellow signal sends 0b10100000 at the first although I wrote codes as following:
In this case, should 0b00110000 be sent, shouldn't it?
Please tell me how to resolve this problem.
- Email to a Friend
1/Time = Freq
1/Freq = Time
1/400,000 (400K) = .0000025, or 2.5us
I believe 10us is closer to 100K
I will need to speak with the team about how we should go about helping with the troubleshooting of your I2C interface to your external processor.
- Email to a Friend
Hi mwf_mmfae
Thank you for your response.
I have not resolved this problem yet.
So, I have been waiting to hear from you.
I'm sorry to cause you problem.
Sincerely,
Ishikawa.
- Email to a Friend
0b10100000 = 0xA0. This is the address of the I2C EEPROM in the module. The initial access to the EEPROM always occurs at 100KHz, so the 10uS you see is expected. So the trace here is not of the app accessing the temperature sensor. Can you try capturing that?
- Email to a Friend
Hi arvinds
Thank you for your advice.
OK. I see. I will try to capture the app accessing the temperature sensor signal.
However, I have two questions about this.
The questions are about this sentence : >The initial access to the EEPROM always occurs at 100KHz, so the 10uS you see is expected.
Does the signal to access to EEPROM appear every the i2c connection (write and read)? Although I captured the signal of i2c when I called temperature_sensor_read_16_bit_register function of i2c_temperature_sensor sample many times, the signal of initial access to the EEPROM appears.
If your answer is no, why does initial access signal appear whenever I call temperature_sensor_read_16_bit_register function?
The last one is relevant above question.
When should the signal of app accessing temperature sensor I use appear ?
If there are some mistakes in English, I'd like to apologize.
- Email to a Friend
No.
Is the app crashing? Can you check if the application's create function is called again about 4s after you attempt to read the I2C sensor?
- Email to a Friend
I checked it by using UART, but I couldn't confirm that trace0("create()") in the application's create function is called again. The counter of timeout function worked correctly after I called temperature_sensor_read_16_bit_register function.
- Email to a Friend
The I suggest toggling a GPIO just before the call to cfa_bsc_OpExtended and then using that as a trigger to capture the I2C bus. What you have in the picture is probably happening because of a bleprofile_*NVRAM() call somewhere close to your call to cfa_bsc_OpExtended().
- Email to a Friend
Hello Y I,
The development team does not believe that you are capturing the correct signals on your scope screen shot.
JT
- Email to a Friend
