Hi everyone,
I want to send an array of data. Therefore I'm using the hello_sensor example which I changed a little bit. But I have no success. I only can send 1 Byte instead of 8. Does someone know how to send more than 1 Byte at once?
ReadWrite Characteristics
Hello Andre,
Look at the WICED Sense Example in the SDK 2.2.
We provided a document for the WICED Sense Firmware:
Introduction to Format of WICED Sensor Data
We show a bitmask demo in the code in the wiced_sense.h file:
#define WICED_SENSE_NOTIFICATION_HEADER_INCLUDES_ACCELEROMETER (1 << 0)
#define WICED_SENSE_NOTIFICATION_HEADER_INCLUDES_GYRO (1 << 1)
#define WICED_SENSE_NOTIFICATION_HEADER_INCLUDES_HUMIDITY (1 << 2)
#define WICED_SENSE_NOTIFICATION_HEADER_INCLUDES_MAGNETOMETER (1 << 3)
#define WICED_SENSE_NOTIFICATION_HEADER_INCLUDES_PRESSURE (1 << 4)
#define WICED_SENSE_NOTIFICATION_HEADER_INCLUDES_TEMPERATURE (1 << 5)
#define WICED_SENSE_NUM_FINE_TIMEOUTS_TO_PLAY (5)
#define WICED_SENSE_LED1_DEFAULT_INIT_VALUE (0x0)
#define WICED_SENSE_LED1_DEFAULT_STEP (0x20)
#define WICED_SENSE_LED1_TOGGLE_VALUE_START (0x20)
#define WICED_SENSE_BATTERY_LEVEL_FULL (3000)
#define WICED_SENSE_BATTERY_LEVEL_EMPTY (1800)
JT
Hello Andre,
JT
