C:\Users\PC-ASUS\Documents\WICED\WICED-Smart-SDK-2.2.0\WICED-Smart-SDK\Wiced-Smart\spar/../../Apps/wiced_sense/wiced_sense.c:1267: undefined reference to `sqrt'
i solved the problem was in the conversion from i16_t to double
i have the same problem all the mathematic functions doesn't work i think there's a problem in the links
I am trying to use math functions as well and I am also getting errors such as:
undefined reference to `__aeabi_i2f'
undefined reference to `__aeabi_fmul'
Could you explain how you managed to use math functions included in math.h ?
I think you will find these two threads helpful:
yes i didn't find the way to use that functions even with an external libraries so i used another function that calculate the sqrt only with integers and i multiple the input value (*10,100..) of the function to have the sensibility that i want to get then i devied the output this is the only way i found , the wiced smart sdk do not support floats
this is the code :
#define NEXT(n, i) (((n) + (i)/(n)) >> 1)
int abso (int n)
if (n<0) return (-n);
else return n ;
unsigned int isqrt(int number) {
unsigned int n = 1;
unsigned int n1 = NEXT(n, number);
while(abso(n1 - n) > 1) {
n = n1;
while(n1*n1 > number)
n1--;
return n1;
Thanks for your quick replies!
Besides sqrt, I also need some trigonometric functions, so I will probably look into libfixmath.
