SDK: 2.1.1
Tag: 920737.
app: hello-sensor connected with 4 handset
firmware size ~ 30KB.
Description:
We base on Hello-Sensor to implement multi-client (= 4) to connect with 1 sensor device)
in plan_air_create()
    blecm_ConMuxInit(4);
    blecm_enableConMux();
    blecm_enablescatternet();
Problem:
1th handset connect to device is ok but after 2nd handset tries to connect with device,
it will be randomly disconnected and I print its role  as client.dev_info[con_index].role == SLAVE
(is it correct or should be MASTER?) and the disc reason is 0x8 (what does it mean?)
Possible casue:
- whether or not that some in each connection link,
what is appropriate timing by using bleprofile_SendConnParamUpdateReq.
-  if device is not as master, do i need to get rid of blecm_enablescatternet() call when in create() function.
-  920737 tage can not perform slave to multi-client without putting a master in between.
MichaelF_56
Within our implementation, we can support 2 Clients connecting to one slave, but not more.
I think we already answered this and the disc reason question here in your other post: Re: Hello-Client multi-master connection failure.
MichaelF_56
