WaSu_1697556
http://community.broadcom.com/community/wiced-smart/wiced-smart-forums/blog/2014/06/22/sleep-deepsle...
According to the above blog post, the duration of deep sleep can be configured anywhere from 64mS to ~36 Hrs with internal LPO.
What would be the consequence of specifying the value that's shorter than 64mS or longer than 36Hrs?  Does that simply result in bad time accuracy?
ArvindS_76
If you set it to less than 64mS, then it will round to 64mS. If you attempt to set it to higher than the max value, it will roll over and so you will still get something less than ~36hrs.
ArvindS_76
