Following:
Is there any way to discover how much time has elapsed while asleep?
I am using devlpm_enterLowPowerMode(); to enter sleep mode. Prior to entering sleep, I am making sure to turn all my outputs low as well as executing bleprofile_Discoverable(NO_DISCOVERABLE, NULL); to make sure the module is not broadcasting.
However, measuring the output current from the battery, I am measuring 5mA. Knowing that module should be in microamps in sleep, is there something that I am missing for the current draw to be so high?
Otherwise, the module seems to sleep and upon wake from interrupt, executes a reset.
MichaelF_56
Mochi,
Is this still an issue?
Note that JT has started an excellent sleep/deep sleep blog here: Sleep Deep_Sleep Explanation and Techniques
MichaelF_56
Mochi,
For the most part, sleep/deep sleep seem to be working now as expected.
I actually had the blog open and am reading it. It is helpful, thank you!
