03:21 AM
Jun 29, 2015
03:21 AM
I need the solution for floating point support for BCM20737S
When I declare a float variable(in global) for example (float id=10.5;)It showing the following error "undefined reference to `__aeabi_f2uiz'" in WICED smart ide2.2.1. at the same time when i declare the float variable in Local It not showing error but it print the output in terminal only "ffffffffff" instead of 10.5. For printing i used the following method. ble_trace1("Out:%f\n",id); please give me the exact solution for print and access of float variable.
04:08 PM
Jul 01, 2015
04:08 PM
Hello Ripit,
The floating point data types are NOT supported.
You must use fixed point library.
JT
