Does BRCM have released download and test tools for factory.If use sdk,it's too lower.
Manufacturing and Test
Correct.
We are leveraging our distributors around the world, along with their respective programming centers to handle this functionality.
The SDK and the Command Line tools referenced here: WICED Smart User's Guide
Can be used to program the device over the HCI UART.
For first time programming, this is the only option available.
After the device is initially programmed, you can then use either OTA or the PUART firmware download samples provided within the SDK.
Manufacturing Bluetooth Test Tool Application Note (SDK 2.1 and TAG3 Board) is the only 'test' tool we provide.
Do you have tools for downloading many devices at the same time?
Please get in touch with Avnet China and they will be able to help you on this. You may have to resort to Perl scripts to implement the automation.
Do you mean that BRCM don't have multi-downloader for 20736?
Correct.
