Hi sir ,
I use puart_controller write Handle to peer device ,
then I get the error result.
result 0x0 is success written.
but I don't know ,result:0x7d and 0x3d that What happen thing?
Please use the puart_control example and associated peer applications from within the SDK under: /WICED-Smart-SDK/Apps/puart_control
In addition, there is a well written document there you can reference as well: /WICED-Smart-SDK/Apps/puart_control/PUART-Control.pdf
Many of our customers and distribubtor FAEs have gotten this application up and running with no issues.
Do you have a tag3? I suggest repeating the above on it. I also assume you have discovered a valid handler.
