I am not talking about BCM920732_LE_KIT which I know it does not support but any custom design based on '20732.
Lukas
Hello Lukas,
The SDK 2.0.1 will NOT support any BCM20732 designs.
JT
Hello Lukas,
JT
To be more specific, a BCM20732S based module design will run without any issues within a BCM20736S or BCM20737S based design.
Essentially, all three are pin compatible and the 20737 is the superset device of the 3.
However, as it pertains to development kits and SDK utilization, the new SDK 2.0.1 requires the WICED SMART BCM92073X_LE_KIT development board and cannot be used with the previous BCM920732_LE_KIT development board. For the BCM920732_LE_KIT, you will need to use SDK 1.1
Let me clear about BCM20732S module.
When I use BCM20732S module, which version of SDK can be used?
Are you using the SDK to program a BCM20732S module on your own board?
Are you using the SDK to program a BCM20732S on the SPIL based evaluation kit?
For programming the BCM20732S module in either of above, use SDK 1.1
I understand.
By the way, is 20732A1 integrated module planned?
I'll send you some follow up information Daisuke.
