My customer is checking if there is a more detailed documentation on function call description?
Which function call they can use to write their applications?
Thank you for your support.
MichaelF_56
Unfortunately, the only documentation we provide for the API and related function calls is located within the SDK at doc/API/index.html
Note that in order to open this file correctly, you may need to right click index.html and use the 'Open With' command to select the browser.
MichaelF_56
