Is there a document or specification of HW random number generator of BCM20737?
I found functions ulp_initRandomSeed(), ulp_nextRand(), ulp_getRand() and ulp_rand() in patch.lst but can't find header file or documents.
Can you provide me the following informations?
* function prototype
* Is it a true random generator or pseudo random number generator?
SDK 2.X
Confirming that with SDK 2.0 or later you should use:
/// Provides any number of random bit from the HW random bit generator.
/// \param buffer pointer to a buffer that can hold the random bits.
/// \param length Number of 32-bit numbers to generate.
extern void ulp_rand(UINT32* buffer, UINT32 length);
UINT32 rand_num;
ulp_rand(&rand_num, 1);
Unfortunately, this is not available within SDK 1.1.0.
Also, while this is mentioned in blecen.h, I'm not aware of any formal documentation for this feature.
