I would like a solution where:
1. P0 can be configured as an output low
2. bleprofile_PrepareHidOff() can still be used to enter deep sleep
I would be fine with fully disabling keyscan and/or quadrature operation. GPIO interrupt wake up should still work (not necessary on P0, if that helps).
Please do not refer me to a "pull P0 high" solution; that is not what I am looking for. Thank you.
SDK 1.X
Sleep Modes
0x100 for P0 is high-z. You can use it on SDK 1.x.
you may want to check out the below thread:
How to enter HIDOFF? How to detect if the request is not honored?
Hello Justin,
Please see rtc_sample app that sets up the wake time before going to sleep.
JT
rtc_sample is only part of SDK 2.1.1, however it looks as if SDK 1.1.0 performs similar.
The magical line seems to be:
gpio_configurePin(0, 0, 0x100, 0);
The first parameter is the P0 port (0 / 16).
The second is the P0 pin (0 %16).
The third is a config mask, but the value (0x0100) isn't defined in the gpiodriver.h enum. The ninth bit (index 😎 is commented in the enum:
/// iocfg_p#_adr[8]
/// GPIO configruation bit 8,
/// reserved
The fourth parameter is output low value.
Is this correct? Can you elaborate on the third parameter? Are there any problems using this with SDK 1.1.0?
JW
