Juar_2150386
Level 4
Level 4
Is it possible to debug a CYW20736S on custom board with a JLINK?
I see nothing in the datasheet (hardware recommandation) ? What J-Link is recommended ?
Unfortunately, a document that maps the pins for the SOC to the debugger does not exist.  Only the Help Article noted above which uses the TAG3 board.  The schematic for the TAG3 board is in the Hardware User Guide (SDK 2.x and TAG3 Board)
MichaelF_56
Debugging on this device is limited.
The only debugger I'm aware works/tested is described here: WICED Smart J-Link Debugger
This post discusses alternatives: Segger J-Link debugger alternative
Do you have an AN to know witch PIN of the BCM20736S is used to plug the J-Link debugger?
