Customizing Advertising on WICED Smart
ZhaohuaS_76
25 sign-ins 10 questions asked 10 sign-ins
Overview
On WICED Smart device, the default advertising data includes Flags,Local Name, Class of Device and Service UUID, etc. Developer can customize the advertising data, this document introduce how to make a customized advertising.
Advertising Data Format
The format of advertising data is shown in the follow figure. The data consist of a significant part and a non-significant part. The significant part contains a sequence of AD structure, the non-significant part extends the advertising to 31 octets and shall contain all-zero octets.
Advertising Data Type
About AD type definition, please refer to https://www.bluetooth.org/en-us/specification/assigned-numbers/generic-access-profile .
The following AD types are defined in SDK, it’s in bleprofile.h.
// ADV flag values
enum ble_adv_flag_value
    ADV_FLAGS                             = 0x01,
    ADV_SERVICE_UUID16_MORE              = 0x02,
    ADV_SERVICE_UUID16_COMP              = 0x03,
    ADV_SERVICE_UUID32_MORE              = 0x04,
    ADV_SERVICE_UUID32_COMP              = 0x05,
    ADV_SERVICE_UUID128_MORE             = 0x06,
    ADV_SERVICE_UUID128_COMP             = 0x07,
    ADV_LOCAL_NAME_SHORT                 = 0x08,
    ADV_LOCAL_NAME_COMP                  = 0x09,
    ADV_TX_POWER_LEVEL                   = 0x0A,
    ADV_CLASS_OF_DEVICE                  = 0x0D,
    ADV_SIMPLE_PAIRING_HASH_C            = 0x0E,
    ADV_SIMPLE_PAIRING_RANDOMIZER_R   = 0x0F,
    ADV_TK_VALUE                          = 0x10,
    ADV_OOB_FLAGS                         = 0x11,
    ADV_SLAVE_CONNECTION_INTERVAL_RANGE = 0x12,
    ADV_SERVICE_UUID16                   = 0x14,
    ADV_SERVICE_UUID128                  = 0x15,
    ADV_SERVICE_DATA                     = 0x16,
    ADV_SERVICE_TARGET_PUBLIC_ADR        = 0x17,
    ADV_SERVICE_TARGET_RANDOM_ADR     = 0x18,
    ADV_APPEARANCE                       = 0x19,
    ADV_ADVERTISING_INTERVAL             = 0x1A,
    ADV_3D_INFORMATION_DATA              = 0x3D,
    ADV_MANUFACTURER_DATA                = 0xFF,
Flags
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.1.
Value
Description
Bit
Information
0x01
Flags
0
LE Limited  Discoverable Mode
1
LE General  Discoverable Mode
2
BR/EDR Not  Supported
3
Simultaneous LE  and BR/EDR to Same Device Capable (Controller)
4
Simultaneous LE  and BR/EDR to Same Device Capable (Host)
5..7
Reserved
Service UUIDs
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.2.
A device may list the service UUIDs that it implements in its advertising data.
Value
Description
Information
0x02
16-bit Service UUIDs
More 16-bit UUIDs  available
0x03
Complete list of 16-bit  UUIDs available
0x04
32-bit Service UUIDs
More 32-bit UUIDs  available
0x05
Complete list of 32-bit  UUIDs available
0x06
128-bit Service UUIDs
More 128-bit UUIDs  available
0x07
Complete list of 128-bit UUIDs available
Local Name
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.3.
The Local Name ADtype contains the device name, either complete or shortened. If the name is shortened, the complete device name can be read by reading the device name characteristic.
Value
Description
Information
0x08
Local Name
Shortened local name
0x09
Local Name
Complete local name
Tx Power Level
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.4.
The TX PowerLevel AD type indicates the transmitted power level of the advertising packet.
Value
Description
Information
0x0A
TX Power Level (1 byte)
0xXX:-127  to +127dBm
Note:  when the TX Power Level tag is not present, the TX power level of the packet  is unknown.
Class of Device
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.5.
Value
Description
Information
0x0D
Class of device (3 octets)
Format defined in Assigned Numbers.
Assigned Numbers Specification:
https://www.bluetooth.org/Technical/AssignedNumbers/home.htm
Simple Pairing Hash C-192
Value
Description
Information
0x0E
Simple Pairing Hash C (16  octets)
Format defined in Core  Spec V4.0 [Vol. 2], Part H Section 7.2.2
Simple Pairing Randomizer R-192
Value
Description
Information
0x0F
Simple Pairing Randomizer R (16 ctets)
Security Manager TK Value
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.6.
The Security Manager TK Value only be used over an out-of-band mechanism,the definition as below.
Value
Description
Information
0x10
TK Value
Value as used in pairing  over LE Physical channel.
Format defined in Core  Spec V4.0 [Vol. 3], Part H Section 2.3
Security Manager Out of Band (OOB)
Refer to Core  Spec V4.0 [Vol.3], Part C Section 18.7.
An out of bandmechanism is used by the Security Manager to communicate discovery information as well as other information related to the pairing process.
Value
Description
Bit
Information
0x11
Flag  (1 octet)
0
OOB  Flags Field
(0  = OOB data not present, 1 = OOB data present)
1
LE  supported (Host) (i.e. bit 65 of LMP Extended
Feature  bits Page 1
2
Simultaneous  LE and BR/EDR to Same Device Capable  (Host) (i.e. bit 66 of LMP Extended Feature bits Page 1)
3
Address  type (0 = Public Address, 1 = Random Address)
4..7
Reserved
Slave Connection Interval Range
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.8.
The Slave Connection Interval Range AD type contains the Peripheral’s preferred connection interval range, for all logical connections.
Value
Description
Information
0x12
The  first 2 octets defines the minimum value for the   connection interval in the following manner:
connInterval_min=  Conn_Interval_Min * 1.25 ms
Conn_Interval_Min  range: 0x0006 to 0x0C80
Value  of 0xFFFF indicates no specific minimum.
Values  outside the range are reserved. (excluding 0xFFFF)
The  second 2 octets defines the maximum value for the connection interval in the   following manner:
connInterval_max=   Conn_Interval_Max * 1.25 ms
Conn_Interval_Max   range: 0x0006 to 0x0C80
Conn_Interval_Max   shall be equal to or greater than the onn_Interval_Min.
Value of 0xFFFF indicates no specific maximum.
Values outside the range are reserved (excluding 0xFFFF)
Service Solicitation
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.9.
One of the Service Solicitation AD types may be sent to invite other devices that expose one or more of the services specified in the Service Solicitation data to connect. This enables a Central providing one or more of these services to connect to this Peripheral.
Value
Description
Information
x14
Service UUIDs
List of 16 bit Service UUIDs
0x15
Service UUIDs
List of 128 bit Service UUID
Service Data
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.10.
The Service Data AD type consists of a service UUID with the data associated with that service.
Value
Description
Information
0x16
Service Data (2 or more
  octets)
The first 2 octets   contain the 16 bit Service UUID followed by  additional service data
Public Target Address
Refer to Supplement to Core Spec V4.0, Part A Section 1.13.
The public device address is divided into the following two fields:
• company_assigned field is contained in the 24 least significant bits
• company_id field is contained in the 24 most significant bits
Value
Description
0x17
Size: Multiples of 6 octets
The format of each 6 octet address is the same as the Public Device Address defined in Core Spec V4.0 [Vol. 6], Part B, Section 1.3.
The Public Target Address value shall be the enumerated value as   defined by Bluetooth Assigned Numbers.
Assigned Numbers Specification:  https://www.bluetooth.org/Technical/AssignedNumbers/home.htm
Random Target Address
Refer to Supplement to Core Spec V4.0, Part A Section 1.14.
The random device address is divided into the following two fields:
• hash field is contained in the 24 least significant bits, as defined in [Vol. 3] Part C, Section 10.8.2.3.
• random field is contained in the 24 most significant bits, as defined in [Vol. 3] Part C, Section 10.8.2.2.
Value
Description
0x18
The format of each 6   octet address is the same as the Random Device Address defined in Core Spec   V4.0 [Vol. 6], Part B, Section 1.3.
The Random Target Address   value shall be the enumerated value as defined by Bluetooth Assigned Numbers.
Appearance
Refer to Supplement to Core Spec V4.0, Part A Section 1.12.
Value
Information
0x19
The   Appearance value shall be the enumerated value as defined by Bluetooth   Assigned Numbers.
Advertising Interval
The advertising Interval shall be an integer multiple of 0.625ms in the range of 20ms to 10.24s.
If the advertising event type is either a scannable undirected event type or a non-connectable undirected event type, the advertising Interval shall not be less than 100ms. If the advertising event type is a connectable undirected event type, the advertising Interval can be 20ms or greater.
Value
Information
0x1A
Size:   2 octets (UINT16)
Units:   0.625ms
Manufacturer Specific Data
Refer to Core Spec V4.0 [Vol.3], Part C Section 18.11.
The Manufacturer Specific AD type is used for manufacturer specific data.
Value
Description
Information
0xFF
Manufacturer   Specific Data (2 or more octets)
The   first 2 octets contain the Company Identifier Code followed by additional   manufacturer specific data
Sample Code
The follow sample code is in hello_sensor.c.
void hello_sensor_create(void)
    // Read value of the service from GATT DB.
    bleprofile_ReadHandle(HANDLE_HELLO_SENSOR_SERVICE_UUID, &db_pdu);
    if (db_pdu.len != 16)
        ble_trace1("hello_sensor bad service UUID len: %d\n", db_pdu.len);
    else
        BLE_ADV_FIELD adv[3];
        //Advertising data type: Flags
        adv[0].len     = 1 + 1;
        adv[0].val     = ADV_FLAGS;
        adv[0].data[0] = LE_LIMITED_DISCOVERABLE | BR_EDR_NOT_SUPPORTED;
       //Advertising data type: service UUIDs
        adv[1].len     = 16 + 1;
        adv[1].val     = ADV_SERVICE_UUID128_COMP;
        memcpy(adv[1].data, db_pdu.pdu, 16);
        //Advertising data type: Name
        adv[2].len      = strlen(bleprofile_p_cfg->local_name) + 1;
        adv[2].val      = ADV_LOCAL_NAME_COMP;
        memcpy(adv[2].data, bleprofile_p_cfg->local_name, adv[2].len - 1);
        //Generate the advertising packet by above three data types
        bleprofile_GenerateADVData(adv, 3);
//Start to advertising
    bleprofile_Discoverable(HIGH_UNDIRECTED_DISCOVERABLE, hello_sensor_remote_addr);
