I am using the BCM20732S as a secondary processor, and the main processor will be determining when the PCB circuitry can be put into low power modes. For low power operation of the BCM20732S, I am wondering if someone can tell me the current draw of BCM20732S while it is held in reset? Does anyone have experience with this as a low-power sleep alternative?
Aaron
MasterSlave
SDK 1.X
Sleep Modes
I asked around, and it seems that holding the chip in reset might be a valid solution as the LDO would still be on but not consuming a lot of power; the power consumption in this mode might be comparable to an equivalent HIDOFF measurement.
We are not planning on documenting this in the datasheet, but we are guessing that the current is probably in the 1uA range?
