From this thread: wiced sense fails to invoke advertisement stopped callback
I run into the same issue. tried cgs work around. It is still not working.
To confirm I am doing the right thing
1. I modified WICED-Smart-SDK/Tool/wcg/cpy/makefile.inc to
# Add Application sources here.
GGS_LIST += $(DIR)/app.cgs
2. created a app.cgs file under wiced_sense directory
ENTRY "PMU Crystal Warm up Time"
   "Crystal warm up time" = 5000
The reason I doubt whether I am doing the right thing is - Even if I specify a none-exist cgs file in this makefile.inc, make target process still go through and download still complete without any error.
Hello John,
Have you checked these posts:
Re: BCM20732S to BCM20736S migration problem
Re: Wiced Sense factory recovery
This should help
JT
