My compunter is 64bit window7.
I was working with WICED Smart IDE 2.0.1 for a while , and finally it could not execute often.
Now I can not open IDE at all.
Error message is EXCEPTION_ACCESS_VIOLATION.
I read previous discussion so I changed java version into 32bit.
but it does not open.
I added the error message.
Can anybody help me?
Thank you.
I am using IDE on Win7 64 bits and do not see any problems. Maybe you should submit Java issue to Sun as specified in the bug report header. The problem seems to be in the registry access code which is weird. I am not sure if reinstall of JRE and Eclipse would help, but it might worth trying. By the way there were reports of people having problem running software on the virtual machine.
