How do I configure transmitWindowOffset and transmitWindowSize for connection event?
Thanks!
Hello Vincent,
1.  I actually depends on what other connections the master needs to service
2.  The only available timing that you can utilize is what is in the BLE Specifications
Hope this helps,
JT
Hello Vincent,
Are you working on a Broadcom WiFi Product?
I'm working with BLE 20736.
Thanks!
MichaelF_56
We spoke to the developers and they are not aware of these two functions (they even grep'd through the code just in case)
The Wi-Fi SDK contains similar APIs, but not BLE.
I'm looking at the BLUETOOTH SPEC Ver4.0[Vol 6] in section 4.5.3 Connection Event Transmit Window.  Is this the same version being implemented?  Maybe these parameters are fix?
Thanks!
Hello Vincent,
Sorry that we don't understand your question:
The developers informed us that according to the spec, connection events do not have offsets and windows.
Thank you,
JT
okay, let me rephrase the question and hopefully that may help.
When the initiator sends the CONNECT_REQ, at what time will it transmit its first poll data?
CONNECT_REQ <-> 1.25ms + offset + window size <-> first connection interval event [M->S]
Sorry for any confusion on the terms.
Thanks!
Hello Vincent,
Hope this helps,
JT
