Compiling sparinit.c
Can't locate utf8.pm in @INC (@INC contains: .) at scripts/generatelibinstaller.pl line 101, <SYMBOLS> line 1.
BEGIN failed--compilation aborted, <SYMBOLS> line 1.
make.exe[1]: *** [../../build/floor_2_ceiling_master-BCM920737TAG_Q32-rom-ram-Wiced-release/lib_installer.c] Error 2
gcc/rules_cm3_gcc.inc:122: recipe for target '../../build/floor_2_ceiling_master-BCM920737TAG_Q32-rom-ram-Wiced-release/lib_installer.c' failed
make.exe[1]: *** Deleting file '../../build/floor_2_ceiling_master-BCM920737TAG_Q32-rom-ram-Wiced-release/lib_installer.c'
Makefile:329: recipe for target 'floor_2_ceiling_master-BCM920737TAG_Q32' failed
make: *** [floor_2_ceiling_master-BCM920737TAG_Q32] Error 2
Hi meherkollipara,
While we haven't seen your exact error, let me share two things that worked for us.
First: if this is a Linux system (with the apt-get command), try installing perl-base:
apt-get install perl-base
Second: Replace the perl included in the SDK with a symlink to your system perl:
ln -sf /usr/bin/perl WICED-Smart-SDK-2.1.0/Tools/common/Linux64/perl
ln -sf /usr/bin/perl WICED-Smart-SDK-2.1.0/Tools/common/OSX/perl
I hope this works for you.
--Blake.
MichaelF_56
I'll look into this with the developers. I believe UTF-8 is a universal characterset library.
I'm struggling to find someone internally that knows about Perl and this error in particular. Our guess is that this has something to do with the paths/missing dlls/something similar.  This is a first for us.
Hi meherkollipara,
--Blake.
