Hey,
i tested the sample code "heart_rate_monitor" on BCM920732_BLE_KIT and with LightBlue on my mac. Works great.
So i deleted the last service "UUID_SERVICE_DEVICE_INFORMATION" in the variable blehrm_spar_db_data[] but in LightBlue
were all services (1801,1800,180D,180A).
Or with "hello_sensor" i saw with LightBlue the services 1801,1800,180D,180A and the last service UUID_SERVICE_BATTERY (180F) is missing??
Always the same 4 services 1801,1800,180D,180A. Neither more nor less
Am I on the completely wrong way?!?
Sorry, if you are using 20732 your filenames would show 20732. I was referencing 36/37 and SDK 2.0.
DLConfigBD_ADDRFALG is Bluetoooth Device Address to be programmed in your device. The asterisks allows build environment to create a kind of random address. So that you program 5 different devices on 5 computers the address will be unique. You can change that to be specific 12 hex digits. Like 20732A000001, or 00caba1ca99e.
