01:11 AM
Nov 19, 2013
01:11 AM
Hi Sir, Can I use SDK 1.0.1 to support client & server mode with two BCM20732 application? Ex1. BCM20732(Client) <--Pairing-> BCM20732(HR profile server) Ex2. BCM20732(Client) <--Pairing-> BCM20732(HR profile server) <-Pairing--> BCM20732(Proximity profile server) <-Pairing--> how many server can be support ? Ex3. BCM20732(Client) <--Pairing-> BCM20732(HR + Findme + Proximity profile server) Should I refer which sample code ? thanks a lot.
- application
- bcm20732
- bcm20732client
- bcm20732hr
- bcm20732proximity
- client
- code
- findme
- mode
- profile
- proximity
- refer
- sample
- server
- support
01:01 PM
Dec 11, 2013
01:01 PM
As victorz mentioned, thats the plan.
Nov 20, 2013
06:03 AM
Nov 20, 2013
06:03 AM
My apologies, but I do not understand the question. Are you asking whether or not you can setup one of the sample applications within the SDK as a client and/or server on two seperate instances of the BCM20732S module?Or is the question related to how many servers can run within a single instance of the Proximity profile/application?Also, please clarify your reference to the HR Profile server (Heart Rate Monitor?).
07:08 PM
Nov 20, 2013
07:08 PM
My apologies, but I do not understand the question. Are you asking whether or not you can setup one of the sample applications within the SDK as a client and/or server on two seperate instances of the BCM20732S module? Yes! Can BCM20732 be configured as central mode(like phone side) ? The application is that two BCM20732 communicate each other.^^
04:30 AM
Nov 22, 2013
04:30 AM
Are you asking whether or not you can setup one of the sample applications within the SDK as a client and/or server on two seperate instances of the BCM20732S module?Ans: Yes! Can BCM20732 be configured as central mode(like phone side) ? The application is that two BCM20732 communicate each other.^^
Nov 22, 2013
09:22 AM
Nov 22, 2013
09:22 AM
I confirmed last night with the application development team that the BCM20732 can indeed can work as both a central and peripheral device. However, SDK 1.0.1 does not provide a suitable example of a central device. We are however planning on provide some client samples in SDK 1.1, which will be released soon.
06:50 PM
Nov 24, 2013
06:50 PM
I confirmed last night with the application development team that the BCM20732 can indeed can work as both a central and peripheral device. However, SDK 1.0.1 does not provide a suitable example of a central device. We are however planning on provide some client samples in SDK 1.1, which will be released soon.Mike,can you release 1.1 at the end of this year?
Dec 03, 2013
12:13 AM
Dec 03, 2013
12:13 AM
thats the plan
05:20 AM
Dec 11, 2013
05:20 AM
So, can broadcom deliver WICED SMART 1.1.0 on time at the end of 2013?
Dec 11, 2013
01:01 PM
Dec 11, 2013
01:01 PM
