CYBT-413034-02: "LE Set Scan Parameters Command" returns "COMMAND DISALLOWED (0x0C)"
AnHu_4662101
First like given
Tryin to configure the LE Scan params for my CYBT-413034-02 device returns:
Status: Command Disallowed (0x0c)
Complete command is:
hcitool cmd 0x08 0x000B 0x01 0x04 0x00 0x04 0x00 0x01 0x00
Trace:
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #1 [hci0] 2.327627
  Type: Active (0x01)
  Interval: 2.500 msec (0x0004)
  Window: 2.500 msec (0x0004)
  Own address type: Random (0x01)
  Filter policy: Accept all advertisement (0x00)
> HCI Event: Command Complete (0x0e) plen 4 #2 [hci0] 2.331126
   LE Set Scan Parameters (0x08|0x000b) ncmd 1
  Status:
@ RAW Close: hcitool  {0x0003} [hci0] 2.331223
AnHu_4662101
First like given
Actually resetting the dongle before this command makes the command work.
hcitool cmd 0x03 0x0003
Complete trace:
@ RAW Open: hcitool (privileged) version 2.22 {0x0003} [hci0] 2.009234
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #1 [hci0] 2.009534
  Type: Active (0x01)
> HCI Event: Command Complete (0x0e) plen 4 #2 [hci0] 2.013290
  Status:
@ RAW Close: hcitool  {0x0003} [hci0] 2.013419
@ RAW Open: hcitool (privileged) version 2.22 {0x0003} 4.485877
@ RAW Close: hcitool  {0x0003} 4.486335
@ RAW Open: hcitool (privileged) version 2.22 {0x0003} [hci0] 4.486409
< HCI Command: Reset (0x03|0x0003) plen 0 #3 [hci0] 4.486593
> HCI Event: Command Complete (0x0e) plen 4 #4 [hci0] 4.492259
   Reset (0x03|0x0003) ncmd 1
  Status:
Success (0x00)
@ RAW Close: hcitool  {0x0003} [hci0] 4.492369
@ RAW Open: hcitool (privileged) version 2.22 {0x0003} 5.421909
@ RAW Close: hcitool  {0x0003} 5.421981
@ RAW Open: hcitool (privileged) version 2.22 {0x0003} [hci0] 5.422055
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #5 [hci0] 5.422349
  Type: Active (0x01)
> HCI Event: Command Complete (0x0e) plen 4 #6 [hci0] 5.426316
  Status:
Success (0x00)
@ RAW Close: hcitool  {0x0003} [hci0] 5.426559
AnHu_4662101
First like given
Complete trace:
  Type: Active (0x01)
  Status:
  Status:
Success (0x00)
  Type: Active (0x01)
  Status:
Success (0x00)
Yes, That's correct. You have to send HCI reset command first and see if you are getting a success response.
Then only you should proceed with next commands.
Anjana
