Bug in accelerometer driver for WICED Sense (lis3dsh_driver.h)
I've found that the defined values for Control register 5 doesn't match with the datasheet. This bug directly affects Full-Scale setting (sensitivity) of the sensor.
In "lis3dsh_driver.h" from line 250 to 255 should be fixed this way.
//CONTROL REGISTER 5
#define CNTL5 0x24
#define BW BIT(6)      //from BIT(7)
#define FSCALE BIT(3)  //from BIT(5)
#define ST BIT(1)      //from BIT(2)
#define SIM BIT(0)
Moreover, be careful when you have to call GetAccAxesRaw(AxesRaw_t* buff) because it will divide the raw value by 16.
They cost me a few hours finding what's wrong with my code.
MichaelF_56
Thanks for reporting this to the community.
jakewtorres
MichaelF_56
jakewtorres
