MiTo_1583836
I am just starting a discussion on BT (LE) protocol analyzer/sniffer. Could you please share your experience with some of the equipment out there that you are using regularly to analyze a BT transmission? Also it would be helpful to put the pros/cons of the equipment/solution with a bit of your experience.
Ok understood, discussion closed on my side. I will take a look at the trace tool that you are pointing to.
ShawnA_01
25 solutions authored 10 solutions authored 5 solutions authored
It may not be applicable to turn the Broadcom forum into a popularity contest / advertisement vehicle for the packet sniffer companies!
Do some homework via good old Google and reading other user's reviews.
The people I've worked with tend to use Frontline equipment but if you just want to sniff packets, have you seen this:  Bluetooth Trace Tool
No question is ever a bad question, and I certainly do not run the Forum for Broadcom so maybe a free-for-all conversation thread on the merits of what equipment "is" out there is warranted.   Let's see where it progresses.   You have a cool username... would like to someday hear what it's referencing.  🙂
MichaelF_56
I know that this one from BlueRadios was recommended by another user:
http://www.blueradios.com/hardware_BlueSniff.htm
In addition, we also provide our own sBT Trace tool: Bluetooth Trace Tool
Many find this one helpful as well.
