I am trying to make a ble connection between 2 psoc 6 pioneer kit using wiced studio. I advertise data from one and scan from the other. I read the advertise address and confirm it in scanner board. However wiced_bt_gatt_le_connect returns 0, although I checked the parameters. Should I change anything about default or should I add the advertiser and scanner to white list manually.
Please refer this similar thread: wiced_bt_gatt_le_connect function always returns WICED_FALSE (0)
Also, you can try adding both the devices in white list and check.
