Smart Bluetooth
JoFo_1316796
New Contributor
Can anyone please point me to Schematics and Layout (Gerber and CAD source) for the BCM92073X_LE_KIT??
BCM92073X_LE_KIT
Thank You!
JB.
Hello johnnysax,
I just posted them to the forum:
BCM20737TAG Board - Gerbers and Schematics
I have a few more items to post, but that should get you started.
JT
JoFo_1316796
New Contributor
This is referred to as the "TAG3" board in the HW documentation PDF.  But I need the source files so I can layout my board!
Thank You,
JB.
Hello Johnny,
We are working on publishing the files for the TAG3 board and will send you a link shortly.
JT
JoFo_1316796
New Contributor
Hi JT,
What is your ETA for these files?  We need them urgently.
Thank You,
JB.
JoFo_1316796
New Contributor
Hi JT,
It has been three (3) days now without a response?
When should I expect the files?
Thank You,
JB.
Hello johnnsax,
They are being released today - I will send you the link.
The Title of your post mentioned firmware.
Have you downloaded the SDK 1.0.1?
JT
Hello johnnysax,
JT
JoFo_1316796
New Contributor
False,
I am looking for BOTH schematic netlist and PCB source files in the source form.  I am trying to import them into Altium and layout a board.
The board I am looking for is:   BCM920732TAG_032
It looks like this:
Again, I need both the layout source and the schematic netlist.
ShawnA_01
Sorry about the confusing naming convention, and stenciling JohnnySax!
Even though the board you show is stenciled with "BCM920732TAG_O32", it truly is a TAG3 board.  You may also sometimes see it called "TAG2" board, but that is really old terminology.
Basically there are three evaluation boards out there:
TAG_Q32 --- (Note: that is a 'Q', not an 'O') and is populated with the BCM20732 device (i.e. TAG2 board)
TAG3 -- populated with a BCM20737 device (i.e. TAG3 board)
SB-BLE-S02 PEVB --- populated with the BCM20732S module (SPIL Module EVB)
There is soon to be a "Sensor TAG" board that marries up the 20736/7 to a bunch of sensors.
Some folks have de-populated the TAG boards and put other chips on them based on what they are trying to cobble together.   For example, you can populate a SB-BLE-S02 PEVB with a BCM20736S module.
