How can I get the BCM920736 to work as a master? I see that there is a hello_client example code, but it seems that this is specific to the hello_sensor example. But what if I want to do a discovery for multiple peripherals? How can I connect to more than one peripheral.
thanks
Pawel
Hello Pawel and Eric
The Hello_Client Example does show the use of the 20736 acting as a master communicating with the Hello_Sensor application.  This is a great starting point for a Master/Slave scenario.
We will release a multipe Master/Slave example in the final release of the SDK 2.0
JT
JT
