Smart Bluetooth Forum Discussions
Where can I find technical description of the BCM920732_BLE_KIT?
MichaelF_56
Here's a few links to the older BCM20732 based development kit, which is commonly referred to here as TAG2.  Note that there are similar documents available for the newer TAG3 development kit as well.
Hardware User Guide (SDK 1.x and TAG2 Board)
WICED Smart Quick Start Guide (SDK 1.x and TAG2 Board)
WICED™ Smart Hardware Interfaces (used for both TAG2 and TAG3)
The BCM20732 datasheets are here:
BCM20732 SOC Data Sheet
BCM20732S Bluetooth Low Energy SiP Module Technical Reference
MichaelF_56
Thank you! This is very helpful.
BTW - what is the diff between TAG2 and TAG3?
TAG 3 = A1 Firmware, BCM20736/37, SDK 2.X
TAG2 = A0 firmware, BCM20732, SDK 1.1
If you are starting a new design, TAG3 and the BCM20736/37 are recommended.
Thanks!
I'll use TAG3.
Hi Again,
Where can I find the 20737 Datasheet and other technical documentation?
Thanks in advance,
Rami
The datasheets for all SOC (chip on board), as well as SIP (module) are here on the forum.  Do a "search" for 20737, then on the left side, click the "Documents" radio icon.  It will show up at the top.
Thanks Shawn!
Thanks!
