04:56 PM
Jul 07, 2014
04:56 PM
I have attached firmware files that are a straightforward modification of the hello_sensor app for the BCM20736S/BCM20736 for use with SDK2.0.1 and beyond. The firmware and Word document outline the steps to make use of DEEP SLEEP/HidOff modes. The example shortens the Advertising duration to 30 seconds if after 30 seconds the device has not connected then the Device will go into DEEP SLEEP. The other scenario that will cause the device to go into DEEP SLEEP is if it has established a connection and then the connection has been closed. The firmware details and Power Consumption measurements are outlined in the Word Doc.
Happy Programming!!
Frank
Labels
SDK 2.X
Sleep Modes
