brianb instructed me to go to this community to get the 20736 data sheet and I can't find it. All the links just take me in circles. Where is the actual datasheet?
I want to understand if the part has a flexible clock or if it can only accept a +/-20ppm reference source.
RayS
Clocks (InternalExternal)
Module or SoC? The 20736 Module Datasheet is here: BCM20736S Bluetooth Low Energy SiP Module Technical Reference
The SoC datasheet is here: BCM20737 SOC Data Sheet
Note that the 20736/37 are identical from a HW perspective. The only difference is that the 20736 does not support the RSA security libraries.
The 20736 SoC datasheet is here: BCM20736 SOC Data Sheet
