I fabricated and assembled 5 custom BLE boards with BCM20732S. 1 of it does not even program, but 4 of them can be detected and programmed with the ROM Heart Rate Monitor sample app successfully.
However, only 1 of them works fine. The other 3 will only advertise during startup and then stops advertising. I couldn't figure out why 1 of them works perfectly fine, while the other 3 stops advertising after startup.
Any help?
asridharan
10 comments on KBA 5 comments on KBA First comment on KBA
See if Re: BCM20732S module keeps crashing helps. Also search through the forums for discussions containing 'crystal warrmup' (or xtal warmup).
asridharan
Confirm disabling the sleep fixed the problem. Thanks!
