How much is the maximum transmission speed of the BCM20732(SDK-1.1.0)?
How much can be transmitted at a time?
Can be transmitted per second in the BCM20732 about 100kbyte data?
BoonT_56
ble uses the gfsk modulation scheme to achieve a signaling rate of 1mbits/s. The maximum throughput is around 300kbits/s.
BoonT_56
ShawnA_01
25 solutions authored 10 solutions authored 5 solutions authored
There are more articles on throughput here:   Re: Maximum BLE throughput for reliable data transfer
and here: Re: How do I use a maximum throughput?
And our expert states at the GATT layer you can see ~80kbps here:  Re: How to get started (coming from arduino)
