Hi, I'm just beginning coding with BCMs. I have very little coding knowledge but need the BCMs for a project.
I have two Bluetooth connected BCMs. The master is running the Hello_Client application. I am trying to transmit/print the data collected by the hello_client BCM via UART (as opposed to the trace), i.e. I can see the data in COM 3 but would like to transmit it to COM 4. I feel like puart_write and puart_print are the best ways to achieve this but am having no luck so far.
Does anyone know a good way of achieving this?
Any help is greatly appreciated, thanks in advance.
huangj
Level 4
Level 4
Here is a sample code for pUART.
Hope this helps....
Jack
BoonT_56
Did you have a chance to review the sample app "puart_control" in the SDK? There is a PDF doc within the folder that will spell out the details on the usage.
huangj
Level 4
Level 4
Hope this helps....
Jack
