- Email to a Friend
I'm not able to keep advertisements going while a connection is up. Debug suggest that advertisements are being shut off by the stack. From my connection_up callback:
16:52:55 - connection_up: ac220b4088d0 h=64
16:52:55 - Tx buffer = 15
16:52:55 -
16:52:55 - blecm evt handler:
16:52:55 - 0e04010a200c
16:52:55 Connection is UP.
16:52:55 profile idle timer stop
16:52:55 connUp
16:52:55 noAdv
16:52:55 BLE_idleconn:timer(0)
This is after commenting out the line that explicitly stops advertisements. I also tried enabling via bleprofile_Discoverable in the same spot with no success. Debug showed BLE_low_un_adv:timer(0) but nothing was picked up on my scans. Ideas?
void my_connection_up(void)
isss_hs_connection_handle = (UINT16)emconinfo_getConnHandle();
UINT8 *bda = (UINT8 *)emconninfo_getPeerPubAddr();
// Save address of the connected device and print it out.
memcpy(isss_hs_remote_addr, bda, sizeof(isss_hs_remote_addr));
ble_trace3("connection_up: %08x%04x h=%d",
(isss_hs_remote_addr[5] << 24) + (isss_hs_remote_addr[4] << 16) +
(isss_hs_remote_addr[3] << 😎 + isss_hs_remote_addr[2],
(isss_hs_remote_addr[1] << 😎 + isss_hs_remote_addr[0],
isss_hs_connection_handle);
// Prepare generated code for connection - write persistent values from __HOSTINFO to GATT DB
__on_connection_up();
// ToDo: Write custom persistent values into GATT database using functions
// changed_<service_name>_<char_name>() generated by smart disigner
// If device supports a single connection, stop advertising
//bleprofile_Discoverable(NO_DISCOVERABLE, NULL);
//This didn't work.
//bleprofile_Discoverable(LOW_UNDIRECTED_DISCOVERABLE, NULL);
// If security is required for every connection following function will start bonding or
// will setup encryption. No indications or notifications should be sent until
// encryption is not done.
if (bleprofile_p_cfg->encr_required & SECURITY_REQUEST)
if (emconninfo_deviceBonded())
ble_trace0("device bonded");
else
ble_trace0("device not bonded");
lesmp_sendSecurityRequest();
2.1.1 SDK/BCM20736
SDK 2.X
- Email to a Friend
When connection is up you can restart the advertisement using
blecm_setAdvDuringConnEnable(TRUE);
- Email to a Friend
I'll ask one of the developers to comment on the issue.
- Email to a Friend
- Email to a Friend
I could have sworn this worked when I put it in... For some reason I'm once again not seeing advertisements when connected. Is there anything I can query to help figure out why the stack isn't sending them out?
bleprofile_GetDiscoverable() is returning 3 (LOW_UNDIRECTED_DISCOVERABLE) at the end of connection_up()
- Email to a Friend
Do you have APP_PATCHES_AND_LIBS += central_role_patches.a included in your make.
- Email to a Friend
I do now. Still no dice. I am configured as a peripheral though, so I don't see how central patches will help.
- Email to a Friend
I'm just trying to achieve the same. Since it dawned on me that blecen is needed, I tried to get hello_client to send advertisments if I connect with gattool to it. I achieved this by changing part of the hello_client_connection_up() callback:
if (hello_client.num_slaves < HELLO_CLIENT_MAX_SLAVES)
// if we are not connected to the master enable advertisements
if (!hello_client.handle_to_master)
ble_trace0("Adv during conn enable");
bleprofile_Discoverable(LOW_UNDIRECTED_DISCOVERABLE, NULL );
else
ble_trace0("Adv during conn disable");
// added advertisments here too
// blecm_setAdvDuringConnEnable(FALSE);
// blecen_Scan(LOW_SCAN);
Verifying with SmartRF shows advertisments coming from the hello_client device while gatttool has a connection open to it.
Kilian
- Email to a Friend
I am sorry for the confusion, but central functionality should not be required for advertisements during connection. Meanwhile the advertisements during connection means that the second connection as a slave may be created. So you need to tell stack that scatternet is allowed. I modified hello_sensor to add in the create
blecm_enablescatternet();
and changed in the connection_up
to
seems to work.
- Email to a Friend
Enabling scatternet seems to have done the trick. Going back and forth with and without it confirms it.
I'm not sure why I thought this was working before. Is there a possibility that I could have seen adverts during a connection without it at some point?
- Email to a Friend
Not likely. You might have seen the adverts if connection has failed.
- Email to a Friend
Ok, I'll buy that. I did have some bad ptr accesses a while back that were causing occasional disconnects. Thanks for the help!
- Email to a Friend
Just for completeness sake, in the connection up callback I was able to use
blecm_setAdvEnable(0);
blecm_setAdvParam(interval,
_ADV_ADV_INDIRECT,
_ADV_PUBLIC_ADDRESS,
_ADV_ADV_CHANNEL_MAP_MASK,
_ADV_ADV_FILTER_POLICY_WHITE_LIST_NOT_USED,
NULL);
blecm_setAdvEnable(1);
to start advertisments again, which makes me totally happy.
- Email to a Friend
Hi, victorz
Should this function 'blecm_setAdvDuringConnEnable' to be called in every event of connection up?
Or can it be just called once in 'Create' function?
- Email to a Friend
I'm doing the same thing but I'm not seeing advertisements. I'm trying to get a little help in figuring out *why*. When I check, the stack is reporting that it's in LOW_UNDIRECTED_DISCOVERABLE mode but when I connect (via gatttool as well) I no longer see advertisements.
ble_trace1("ADV Disc: %d", bleprofile_GetDiscoverable());
