I see that the BLE_CEN_CFG struct has a member scan_filter_policy with flags HCIULP_SCAN_FILTER_POLICY_WHITE_LIST_(NOT_)USED. Is there a way to add and remove entries from the whitelist? I can't find anything in the headers or docs. Thanks.
See blecm.h:
/// Enables adding items to the whitelist at the stack layer. Needs
/// to be done once during application creation.
void blecm_enableAddressSelection( void );
/// Allows the application to add BD_ADDR to the whitelist.
/// \param p_select_addr Pointer to the first element in the array of BD_ADDRs to be added.
/// \param num Number of BD_ADDRs in this list. Max = 5. Setting num = 0 will clear the list.
/// \return 1 on success; 0 on failure.
int blecm_SelectAddress (BLECM_SELECT_ADDR *p_select_addr, UINT8 num);
