if I calling sequence is like this:
bleprofile_GenerateADVData(adv,2);
bleprofile_GenerateScanRspData(adv_scan,1);
bleprofile_Discoverable(HIGH_UNDIRECTED_DISCOVERABLE, NULL);
ths BCM20732 will not Broadcast!
ths BCM20732 will Broadcast but the ScanRspData is not right! The ScanRspData is the default data which is not i config data.
Please give an answer ,Thanks!
VictorZ_46
5 comments on blog 25 sign-ins 250 likes received
Try to put
    extern UINT8 bleprofile_adv_num;
    extern UINT8 bleprofile_scanrsp_num;
    bleprofile_adv_num = 0x0;
    bleprofile_scanrsp_num = 0x0;
before
bleprofile_Init(bleprofile_p_cfg);
  i got the same issue.
  I'm trying to add scanning response to sample 'hello_sensor'.
  when I write code as such sequence as below. the application will get stuck.
  anyone can comment?
How does the example 'proximity_plus' work for this?
VictorZ_46
Try to put
before
