Hi
I'm designing PCB for custom board using BCM20737S.
Then I have to make the board as small as possible and want radio wave to propagate over about 20 meters.
So, basically I think that the top of PCB abides by the recommended layout in BCM20737S Bluetooth Low Energy SiP Module Technical Reference.
However, I couldn't understand whether the the Keep-Out area showed in Technical Reference also includes others (i.e. bottom layer) or not.
If it includes other layers, perhaps I can't keep the recommendation layout.
In that case, please give me some advice to make board as smaller with keeping radio wave as strong as possible.
Sincerely
PCBLayout
This thread will give you a better idea with pictorial explanations
