SDK: 2.2.1
Tag: 920737.
app: OTA hello-sensor app  .
OTA firmware size ~ 30KB.
Description:
Our customer encounters one problem, they buy 3 devices
and put into 3 rooms, each device with its Tx power set by max. 4-dbm.
First we put devices beside client handset scanning and check client Rx ~ -50~ -60 dbm.
but after put them away from client, distance approximately 20m 25m 35m (of which
Rx is  -70dbm, -80dbm and -95dbm) and the third one is easily disconnected.
Investigation:
- already set     blecm_setTxPowerInADV(4) for 4-dbm.
- is any fading issue there in 20737 tag, any parameter related with for adjustment?
BoonT_56
The figures you obtained are within expectation. Of course we should expect the receive signal strength to decrease gradually according to distance, and eventually so much so resulting in a link drop. In reality where PCB-based antenna is used, the effective range could be much reduced.
BoonT_56
BoonT_56
leo_su
Is this still a concern?
