Is there anyone can give me some simple demo for 20737.Such as ledblink. Just this function.Anything else should be delete.As simple as it can be .
If there is ,thanks!
my mail adrress : 13523698526@163.com
MichaelF_56
Here's a little demo one of our previous interns put together,  I think you will find this helpful: Blink LED using PWM
MichaelF_56
MichaelF_56
Per your email question....
The application runs in its own thread and the entire application framework is event driven
The main entry point of the application is APPLICATION_INIT() where the app has to register its GATT database, configurations and the application create function
No other operations are allowed at this point
Once this is done, the rest of the firmware and the BLE stack will be initialized - and once these are ready- the application create function will be invoked
This is equivalent to C’s main()
Once you return from this function, everything is event driven
Callbacks for connection up/down/end of ADV interval/write to GATT handle, interrupts, timer expiry etc. are all events for the application to handle
So, there is effectively no need for a main() function
