Dear Sir,
we have SIC MOSFET with Gate driver design and refer to the IFX web EVAL_3KW_50V_PSU.
Can you help us to review the schematic and also advise good component vales? thanks!
kind regards,
Kuo
ispn:32181:1:0
l1:314:1:0
Hi Kuo,
I have reviewed your Schematic. You can consider following components
Sic MOSFET - IMZA65R048M1H
Gate driver for Sic MOSFET - 1EDB9275FXUMA1
Gate resistance – 10 ohms or lesser. ( Using higher resistance like 100ohms will increase turn ON and turn OFF time which will increase the switching loss)
Please refer following documents for better design understanding.
https://www.infineon.com/dgdl/Infineon-EiceDRIVER-Gate_resistor_for_power_devices-ApplicationNotes-v...
Application notes:
https://www.infineon.com/dgdl/Infineon-MOSFET_CoolSiC_650V_SiC_trench_power-ApplicationNotes-v04_00-...
You can contact us for further support.
Vignesh kumar.
Hi Kuo,
Thank you for posting on Infineon community.
we can help you in this. please refer the below document to choose the gate Resistor
could you please share the frequency of operation?
Dear Sir,
noted with thinks!
the fs around in 65kHz.
kind regards,
kuo
Hi Kuo,
Application notes:
Vignesh kumar.
